I noticed that one of the rear tires on my '02 968 S with 18" Sport Classic IIs had a slow leak. I figured I had picked up a nail or something similar, but when I pulled the wheel off to investigate, I found the lip of the wheel on the inside was actually cracked. The car is relatively new for me and new Dunlops were installed before I purchased it, so I'm not sure when or how this happened. Now I just need to figure out what to do. New wheels are nearly $700, so I'm thinking about purchasing a take-off from Wheel Enhancement or a refurbished wheel from the Wheel Collision Center. Has anyone ever deal with either of these companies, or have alternative? (eBay is another option, I guess.)
This is what the crack looks like...
On a related note, I was also thinking about having the wheels sent out to be cleaned up and powder coated. I believe Sport Classics are true two-piece wheels and the centers can be unbolted, can anyone cofirm this? If so, is there anything special about disassembly or reassembly, or having the powder coated, that I should take into consideration? What should the perimeter bolts be torqued to when they're reassembled?
Thanks in advance!
This is a 2 piece wheel if I am correctly remembering. It is also manufactured for Porsche by BBS. So at a minimum you should be able to replace the wheel rim and keep your current center to reduce the cost. One of the benefits of modular wheels.
Todd
Tool Pants, Todd,
Thanks for the suggestions, I'll look into both options.
I must say that as a new Boxster owner, I find this site to be a wealth of information. Once the wheels are sorted, I think I will be ready for a DIY 60k service + new rotor/pads all around.
Cheers
cplus
