Hi all,
I have had to fit a new water pump today, and the cooling system go drained. However, I started pouring the antifreeze back in to the system and after about 1 and half litres it hit an air lock and I cant get any more in.
Can some one please help me remove the air lock, what do I have to do?
many thanks
Russ
by the way, I have already used the bleed valve next to the filer cap, and it let some of it back in to the system, but its stopped again
thanks
What if you dont have one of these vacumne kits, is there another way
thanks
You are supposed to have the engine running and the valve open to get the air out.
When I replaced the tank in the trunk I filled up, warmed up the car, lifted up the valve and went for a 15 minute drive.
