Uh, my problems with my 98 Boxter 2.5 won´t end...
The original problem was a huge amount of white smoke coming out, not exactly after the start, but it comes after few minutes.
I changed the oil separator, as it was the first suspect, but it didn´t solve the problem.
What can it be?
I´ve had also the CEL light on, the first time I took the codes out it gave me the following:
0410, 1121, 1147.
I cleared them and drove the car for a while. The CEL light was on again, now showing 0410, 1147, 1411.
I understand nothing as many codes are not Porsche or other standard specifioc at all...
The engine burns a lot of oil. But as said it cannot be the oil separator, so what can I do/ expect????
Kare, Spain
Another problem: sometimes the engine begins to knock (here in Spain we have 95 oct fuel, my car is US model). It goes away, if I go to highway and drive a while. I suppose there is a problem with vario-cam. What is the part I have to check????
Did you read my response on your other thread?
OBD code 1147, cannot find
Please do not double post. Crossposting is a waste of time and valuable resources. If you post the same message in multiple forums, we will delete the ones we feel are inappropriate.
This duplicate post is now closed.
This topic is now closed to further replies.
