My 1999 Boxster came equipped with Litronic headlights. I have popped out the housing, but can't see how to remove the xenon bulb. I have the manual, but this is not covered.
Appreciate a description and/or diagram.
Thanks.
Litronic bulb change
Removal
1. Switch off the light. Release the headlight housing and pull out
forwards slightly.
2. Disconnect the electrical plug connection of the automatic headlight beam adjustment and remove the headlight housing.
3. Release and open the cover with control module. Unscrew the electrical plug connection on the gas discharge lamp (bayonet lock).
4. Rotate lamp fastening anti-clockwise (bayonet lock) and remove together with the gas discharge lamp.
Installation
1. Install a new gas discharge lamp. Lock the cover with control module and insert the headlight housing in the wing.
2. Engage the electrical plug connection of the automatic headlight beam adjustment and lock the headlight housing in the wing.
3. Carry out function check of the headlights.
