My water temp light started to flash.
The next day I checked the cooling tank and it was empty.
I filled the tank up with cooling fluid.
I have owned the car for 8 months now and have seen water at the right side exhaust tip.
Now I see cooling fluid at the exhaust tip.
Any Idea??????
After you refill it, check to make sure it still has the right color after an hour or so of driving. I had the same issue twice. The first time it was the cracked coolant bottle. The second time it was a cracked engine BLOCK! Their should be no residue in the bottle if it is just cracked.
