Has anyone used AutoTop before? Its about 150 dollars which seems alot cheaper than the smart top. Does anyone know the pros and cons of these two products? They both seem easy enough to install. I have a 2000 c2 cab. Aside from the blue wire which you really dont need to connect I dont see any cuting of cables. Your input would be greatly appreciated. Thanks
I've never heard of it. Is it the same principle and does it have the same options?
Thanks for the info. I was just curious. I already have the Smart Top installed and it's a totally different installation. Remove one plug, insert smart top in its place, then replace original plug into the smart top recepticle. It can be swapped out in minutes if you have a warranty issue and it's like it never was there. Nothing is changed except a small recepticle between 2 connectors. I'm sure you know all that.
Mine has worked perfectly, but I agree it's more expensive because it includes electronics rather than just a hack.
Don (just a satisfied Smart top customer, no connection) :)
