The tech manual desribes a two part process, first bleed as normal then use a System 2 tester to bleed the brakes. I'm confused, does anyone actually do ths or can I just bleed as normal with a power bleeder. I'm want to put on some new pads(Pagids) before the next track day.
If you have not taken the brake system apart then just bleed away. I asked Peter why this was was in the workshop manual some time ago and it is if you have replaced the ABS unit. PCA Tech
This is how I do it when you want to go twice as fast. Jeff
