I have a few questions before I swap out the suspension. Do I need to depress the coils on the original springs with a spring clamp type tool? I have the car in the air on Jack stands wheels and calipers off so I thought this would be a great time to do the install. Also one of my front struts is missing a Boot (I bought the PSS9's off a member on 6 speed his shop misplaced the boot) Bilstein is on B/O until the end of Feb. Do I need the boots looking at PET it looks like the GT3 does not have boots as part of the front strut assembly can I get away without the boots for a while? Do I need them at all?
The install looks straight forward just by looking at the exposed parts. Is there a good DIY guide? Any words of Wisdom? Short Cuts etc. before I do the work this weekend?
Thanks in advance.
Well I guess not many people have done this install themselves. I did find it quite easy once I figured out the process. The first strut took me 2 almost 3 hours... The second strut about 20 minutes. I do use air tools so that helps. I did find using a Jack and a pair of spring clamps were very helpful. What took so long? Figuring out how to get the old stut out from under the wheel well. I ended up removing the triangle peice. Also it helps to remove the 10mm bolt that holds the brake wear sensor. It would have been nice to have anther set of hands but it is very doable by yourself.
Question I reused a few parts. the Triangle strut top mount, the ball bearing assemply, the coved washer (Said to reuse that part in the Blilstein doc. I have) and the top and bottom brass color disks (one goes under the large top strut nut. Theother goes over the coved washer.) Did I reuse the right parts? I had the strut, spring and bump stop left.
I highly recommend this as a DIY project. I can't see paying $600-1100 for this job it is not that hard. I still have the rear and sway bars tomorrow. I will give some feedback on the rear tomorrow.
