I changed my spark plugs today '01 non s boxster and now my idle is very rough CEL came on but i don't have an OBD II reader (going to get one tomorrow) anybody have any ideas as to why this happened, the only thing i can think of is the torque on the plugs, i couldn't get my torque wrench to fit i there so i had to estimate how tight they are. any and all help is greatly appriecated.
There is a black plastic electrical connector to each coil, covered by a rubber boot. I pull that boot way back before I disconnect the connector.
After the plug change I then I connect the connector and slide the boot back on. Only way you can see what you are doing and if the connector is actually seated.
I bet you do not have a connector back onto the top of the coil and the engine is running on 5 or less plugs.
i check that, you are probably right since i just unpluged them without moving the boot back. thanks for your help tool pants
