I have a 2002 Carrera Coupe and sometimes when I shift - only for 2nd gear - and when the clutch is not 100% engaged - the gears mash. For all my other gears it appears I only have to depress the clutch say 75%. It also appears that if I am driving the car for over 30 min that the 2nd gear is less sensitive.
I am guessing that my problem could be solved in using a shift adjuster tool. If this is the case could someone let me know how and where I can order this? I searched many sites and have not been successful. Is the shift adjuster that is discussed in a number of posts only for the B&M short shifter?
Thank you
You may get away w/ not fully disengaging the clutch on high gears, but that is wrong and you are asking for trouble. You should always fully push the clutch pedal to the floor when shifting and remove your foot from the accelerator when upshifting.
