When I have driven a few miles and have changed gear a few times my clutch operation becomes noisy.
As I press the pedal I can feel a little resistance and a creaking sound from the rear, like there is a dry bearing or joint in the mechanism.
I have been under the car and traced the sound to the clutch housing.
It's like opening an old barn door with rusty hinges.
Can you suggest which part is causing the sound?
