Does anyone know if it's possible to retrofit Bi-Xenon kit on a halogen-headlamp based Cayenne? Or can you recommend an aftermarket HID/xenon kit for Cayenne which I can have installed professionally by a local dealer in California?
Yeah, Alpha and Xetronic got some pretty good HID bi-xenon kits. You have to build a bracket to hang the ballast. You are looking at $1000.00+ with installation.
However, you may also try to look for the genuine bi-xenon headlights. Like new ready-to-install parts are of the similar cost as the HID kits, but you may save a little bit on installation. Check eBay out.
AlienGG are you familiar with anyone in the SF Bay Area who is a reputable installer of these Alpha/Xetronic kits?
I am a installer for HID in SF bay area my shop is in novato and i live in sausalito. 400$ installed with 2 year warenty. I install these a lot and the f1speck kit is the best for the price. I have installed these on my cayenne in the headlights, fogs, and the turning projectors. call me up if your interested. If you have any problem with them i warenty my self and swap on the spot if i have the part in stock. call me up Justin 415-246-6607 Im also doing all cinds of modifactions to mine so if your interested in anything else let me know
  • 2 months later...
I think Loren will answer that Q. ^_^
I put HIDS in my cayenne no problem very easy install 10 min
I justin first time , I installed hids on my Cayenne 2006 , one little problem , I live in
canada therefor I needed to programme d r l .So when I start up my cayenne 06 lights are off
reducted voltage is sent to my day lights , the hid' s flicker and when the lights are turned on
it works fine .I don't know if programming could solve my problem or lighting my day lights
else where or something............
Edited by Loren
Removed ALL CAPS - please do not post in ALL CAPS
Hi all, I am fighting since more than a month now to get this issue solved and I hope you could help. I have a US cayenne 2004 and I did the complete facelift conversion. All went ok except the headlights, mine has no xenon on it and the new ones I installed are OEM xenon and they don't work ok. I heard about modules or boxes but at unreasonable prices. Any suggestions ? Thanks a lot
I would start with reprogramme (PIWIS tool) the car from Halogen to HID. Perhaps it helps.
  • 7 years later...
Is the automatic range adjustment system for yoir Ned xenon front lights working properly too ?
was there wires ready and brackets front and rear for the sensor/ levelleres ?
I have a 2004 halogen (none xenon) Cayenne.  3,2
the car has now a facelift 2008 turbo front end with xenon, but the range leveling system is not installled.    Is it possible ?  How to do ? Seems like it’s missing wires in the rear.
there is brackets front and rear.   And I have the levelleres, although the electric connector on the front one doesn’t fit...
I have no wires from rear yet.....where red should the wires from rear be connected ?
What kind of programming is neccecary ?
Running dayligh doses not work work when the engine starts.
light switch needs to be switched on before I start the car.......else the front light xenon does not go on.
Any any help to get ?
