I have a 2001 Boxtster S, 6 speed. The stick shift makes a sqeaking sound when used, also there is a sort of quiet thunk for the first four gears.
Is it possible to oil or grease the linkage from above by removing the leather (?) skirt covering the bottom of the shifter ? How do I go about removing this skirt and what type of grease should I use ?
