my cig lighter works, but the light that surrounds it doesn't, i changed the bulb and checked the fuses, still nothing, the new bulb i bought is a12v 1.5 amp is that the right one? the old one never had writing on it to see. cheers
The lighter fuse and the light bulb are not on the same circuit. The lighter has it's own fuse - and the bulb is wired into the other dash lights. If the ashtray light works (as well as other dash night lights) then the lighter bulb should work unless there is a broken wire to the lighter bulb (grey/blue wire).
