I have a 2001 Boxtster S, 6 speed. The stick shift makes a sqeaking sound when used, also there is a sort of quiet thunk for the first four gears.
Is it possible to oil or grease the linkage from above by removing the leather (?) skirt covering the bottom of the shifter ? How do I go about removing this skirt ?
Sorry, I put this into the incorrect forum.
Edited by Berliner
There is lots of good info about the stick shift at this B&M link http://bmracing.com/media/products/pdf/67.pdf
If I were you, I would remove the center console to get at the linkage and leave the leather boot hanging on the shifter in mid air.
