From looking at the connectors on the back of a PCM2 I see no reason why it will not work as a stand alone nav unit/ radio without the MOST optics connected - the speaker connectors, power etc all must be on the ISO connectors and the antenna connectors are on the back.
My question is has anyone actually tried this? I realise that you would not get the directions on the cluster or CDC and phone function but will it still work as a stand alone nav and radio?
Also, does anyone have the pinouts of the ISO connectors and is the speed pulse and night illumination on these?
Are there any other issues with using a non MOST car with this? Mine is a late 2000 986S
If there are issues, has anyone heard of a MOST emulator box like the CAN bus emulators you can get for the Mercedes Comand nav?
All the documentation I've seen shows MOST devices in a loop, with other components. It may be that using a F.O. cable to loop the PCM2 input to output may satisfy the head unit and permit functionality.
The service manuals have the connector pinouts. The Becker web site also has this information, for similar models, using the same connector.
It may even be possible to get an interface cable, with connectors that plug into the PCM2 speaker connectors, from a company like Crutchfield.
