I can’t move my tiptronic gear lever to the park position (p)!
does anyone know what might be the problem?
I can move it to other positions.
BOXSTER 2000
TIPTRONIC
When I swapped my console I had something similar happen, the shift plate had moved into the wrong position. I would take off the knob & cover and have a look as it only takes around 10 mins to do. If you can shift into all gears with the cover off that might be the culprit.
