Can anyone advise if these are the same as the 996? I want to fit PSE which I did on my old 996 so will need to put the car onto stands at the rear. I seem to remember jacking up the entire rear from under the engine somewhere?
Thanks in advance for any advice
Nick
Thanks for the info - on my 996 I managed to change the mufflers by removing the 2 rear wheels with the car supported on stands under the side jacking points. This saved having to remove the rear bodywork as I have no idea how hard or easy this is.
Either way is about the same effort. The rear bumper cover comes off with about 10 small philips head screws, and the heat shields on both side have about 4 bolts each.
Taking the bumper cover off makes placing the mufflers somewhat easier to do, but there is no gain in tightening the 3 nuts that hold each muffler to the engine support bracket. You still have to crawl under the car to get to them.
