Hey All!
Well locating the Problem! Driver window sits differently than the passenger. The driver window at the rear has a gap that is just wider then the width of the keyblade, and the top you can see clearly when looking at it from the side, ie it's not going up into the retaining channel like the passenger side does. Both of the window auto drop features are working as normal but the window just is not sitting where it should be. I have found some clues in past threads but no actual instructions. Thanks in advance
