I having tried on various message boards (with no sucess) to find out if it is possible to switch between degrees F and degrees C.
I have had many people suggest the temp re-circ and the + key but this doesn't work on a 2004 Boxster S.
Is it possible to do this using the PST2, if so what is the method?
Edited by Nick_USA
On the all cars the cars I have tried it on - you do it as follows:
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Note: There are two + keys make sure you press the one under the temperature readout - while holding the recirculate button down.
If that does not work then perhaps something changed in MY04 and you may need a PST2 - if that is the case where are you located (since I have a PST2)?
I have tried the method you suggested on several occasions.
I have not tried the PST2.
I am on the East Coast near Greenwich, some way away from the SF area.
