One more code for the count :cursing: P0441 "fuel ventilation system above limit".
Could it be the EVAP canister shut-off valve, not working properly?
Sometimes I hear a buzzing noice towards the right side of the dashboard.
Could use help with locating/accesing parts and diagnosing. :unsure:
Did somebody got this code? what was the fix?
The OBDII manual says:
"- EVAP canister purge valve open
- Pressure sensor faulty"
The valve is back on the engine - the pressure sensor is back near the engine too.
Thanks Loren,
Your last advise (from previous post) was dead-on :notworthy: (oil separator bellows responsible for codes P1124/P1126)
....Is there a way to check the pressure sensor? or should I just get a new one and replace it?
Edited by Rolando
  • 2 years later...
I have the same Pcode (P0441) on my boxster AND i also hear this faint, yet audiable horn... almost like a whoopy cushion coming from somewhere need the the fuel door lid.... Any advise?
