Does anyone know were to find the engine No on the block, The pad on the side as described in the manual is blank Just rough casting as if never having one , Should it be cast out or stamped in. Am getting a bit worried. Anyone help on this one.
That is where it is. You may need a strong light to see the stamping.
Depending on the state/country you live in it may be on your vehicle registration too.
