My 30k status report says:
O/S/F Air Scoop damaged.
What is this? Is it the air deflector or air splitter?
I had a look and I only see a small crack. Is this something I should worry about?
Cheers again
I guess you are talking about the "snorkle" that brings in cool air to the air cleaner. There are two piece to this - the top most piece (sealing bellows) that seals against the engine deck lid (bonnet) and the longer plastic tube. The bellows can be ordered and the longer plastic tube is part of the lower air cleaner assembly and does not have a separate part number (you would need to by a whole new air cleaner assembly).
If the crack is not too big I would not worry about it. JMHO
