Hello everyone.
Anyone have a quick and dirty on removing the factory footrest and installing the Tekquipment aluminum look one?
Thanks in advance for any info.
The TSB says to follow the instructions in the shop manual. I do not have a 987 manual or a handy car to look like.
On a 986 there was a single phillips screw that you removed and then pulled the footrest off. The TSB says it should take 20 time units and if my math is correct that would be 12 minutes, so I would expect it to be simple like it is on a 987.
