My 997S has been hanging at the "Porsche Charg-o-mat I infusion" for about 3 weeks.
This morning when I checked it in the garage, there was no light on on the charger. When I pull it out of the outlet and re-insert it, the red light comes on just quickly.
Isn't it true that either a red light (when charging) or a green light (when battery is full) should be lit?
If this is the case, how would I be able to determine if the charge is still working properly?
I have the same charger, the light is red when charging and off when the battery is full .
roger
[ I have the same charger, the light is red when charging and off when the battery is full .
roger
Thanks Roger :cheers:
My memory must have been reset during last summer. I would have sworn that it was green the last time I used it (and the battery full).
