C16 uk lux spec
030 sport type running gear
013 sport technick pack
could anybody tell me what they actually mean?
i need to find out what is factory and whats not.thanx in advance.
C16 uk lux spec
:oops: I misread first time and couldn't figure out how to delete my wrong answer!
Edited by 70Sixter
030 is stiffer springs and sway bars and possible also shocks and suspension bushings. This is for the factory 'sport tuned' handling. Since you are ROW030 (Rest-Of-the-World/non-US) this also means the front springs lower the front end about 1/2 inch.
Some sway Sway Bar numbers (from around 2001):
Model ................. Diameter(F/R) ....... Thickness ....... Stiffness
Standard 2.xL ..... 23.1 / 18.5mm ..... 3.4 / 2.5mm .... 1.000 / 1.000
Standard S ......... 23.6 / 18.5mm ..... 3.5 / 2.5mm .... 1.094 / 1.000
M030 S ............... 24.0 / 19.0mm ..... 3.8 / 2.7mm .... 1.211 / 1.145
*Stiffness rating shows that the M030 front bar is 21.1% stiffer on the 'S' model and the rear is 14.5% stiffer. (more understeer-less roll)
Edited by adsach
