light not working, bulb and wiring ok, how does it actually work?
its really pissing me off, thanx in advance.
If the switch is not off, and the bulb is good then chances are it is the microswitch on the front hood latch. If it is the microswitch I would think you would also get an alarm beep when you set the alarm (signifying a zone is open).
Not really, the whole latch has to come out. Re-install requires a realignment of the latch too.
If you you have a volt meter you can check the circuit that way.
