I'm looking for some information on the differneces between the engine and tranny on the c2, c4 and tt. I know the TT has a dif block, is the diffrence only in displacement, or is it beefed up with stronger rods, pistons, crank, etc?? Do all use the same intake and heads??? Does the c4 have the same tranny as the turbo seeing as they are both all wheel drive??
Martin
