My 2003 turbo is difficult to shift well from 1st to 2nd in that the rpms drop more slowly in first gear when I put in the clutch than in the other gears. I find that I have to wait longer to grab 2nd gear than I should while the engine rpms drop. This only happens in first gear, the other 5 speeds are fine. Why is the engine computer doing this? The tach drops like a rock in 2nd to 6th. Would a GIAC remap fix this? I came out of an M3 which was consistent in all its gears, not that I would go back! :D It's a small thing, but very noticeable. Any ideas?
I think this an emmisions requirement. Does it feel lkike the car is not slowing down as fast as should due to engine braking in gear? Almost as if there is a small amount of throttle built in?
If so, we can thank emissions regulation for this issue. Something about the car making less emmission if the throttle is not closed completely.
Edited by Ari
