I have a 2000 S. Bought the B & M shifter kit, I have the boot pulled up, but can't find the set screw to remove the shift knob. Any help would be appreciated.
JC
The stock knobs do not have a set screw -- only the optional knobs do. If you have a stock knob you will need to twist and pull up to get it off - to be safe open the top first - sometimes they come off with a jolt!
