Does anybody have a problem with starting up the Boxster and hearing a loud whining noise? I've isolated it to the fan. If I turn off the fan (turns on automatically on start), the noise goes away. It seems to be an intermittent problem. Any ideas?
When the car is cold you should hear an exhaust emission pump from the passenger side of the car. It does sound like a fan. This pump shuts off after about a minute as the car warms up.
I assume this is what you are hearing. If not then you need to supply more details.
