Does anyone know if the 3 button 986 (Boxster) remote head will work with a 2001 996. I know I only need the 2 buttons, but I want to make sure it will work.
p.s Happy New Year everyone
Probably not, as the way that the fobs transmit the actual key pressed, differs in the two and three button units. It is also necessary to make sure the key/fob comes with a label that has a barcode and number on it. This is used in the programming process.
Finally, if the key is one of the latest type that uses the Crypto Algorithym Immobiliser, once the key is programmed to a car, it can never be programmed to another car - even if all the code numbers are known. Please see this post also. Pay attention to the entry from me (0586slb) and Loren.
Hope this helps.
