I have a 60 gal. , 6hp sears compressor. Its a pretty good deal for the money but if I had to do it over again. The Ingersoll-Rand units with oil fed motors and 2 stage would be the way to go. You'll find that 1/4 drive ratchets and sand blasters will use alot of CFM. Once you've used airtools, its hard to use anything else. Take a look at www.northerntool.com This may give you some ideas.
