Hello all,
Planning on putting this unit in my 99 c2 tiptronic.
Does anyone know here the speed sensor wire is or the speed sensor itself (or if the car even has one)
Has anyone had to find this wire in installing this or other units?
does anyone have any guidance on actually doing the install (from experience or otherwise!)
thanks in advance!
-Dipak
Hello all,
thanks in advance!
-Dipak
Hi, never did it with a 911 before but yea I have done a few. It is a pretty basic thing much like hooking up a power antenna line or amplifier turn on lead. Your unit should measure the output from the wire and adjust the sound of the unit to compensate for that lovely engine purring. Myself I would just skip it and enjoy the sound of the engine! I'm not sure if my stereo adjusts to the speed, but if you know yours did then you'll already have the wire there at the head-unit. Nonethe less I'm sure as soon as everyone sobers up someone will help you out as the wire is in the 911's somewhere as they have speed adjusting power steering. Good luck and this would probably be something cool to get pics of and set up a DIY on Happy New Year!
Happy New Year!
Since it's a NAV unit that he wants to install the speed signal (grey/pink wire) needs to be hooked up for reasonable accuracy. As you said the signal should already be there in the DIN plug behind the current radio.
Otherwise look here:
Thorsten
Edited by toddel68
You guys are great
thanks for the information.
one if the installer who was going to do this said that for the porsche i need to buy a separate $200 speed sensor- this did not make a lot fo sense to me.
at any rate, after i thought about it for a bit- I will likely be taking it to the local porsche stereo shop that I trust (Hurley's in McLean, VA)
They put in my other stereo (planet audio amps, focal 5ws subs, focal polyglass mids/tweeter) so i need to make sure it all "mates" well
Plus i am sure i will need some custrom trim parts to make it all look oem.
i will post pics as soon as it is done!
thank again!
