transmission fluid question
I plan on changing the transmission fluid in my 2001 boxster this weekend i have read the DIY article and did a search on the process and feel confident about it, my only question is this. In the DIY article it says to fill with fluid untill level with fill hole. In other posts some say to fill 11 mm below the fill hole which is best?
Thanks for your help
