My 00' Boxster makes a thump noise when accelerating, doesnt happen all the time...I feel the thump/knock under the driver seat....any help would be appreciated. :help:
:lightbulb: #1)
Are you the only one driving your car?
Half the time I get my car back from a service appointment, the seat goes clunk as I pull away. The folks who move the car, move the seat but don't wiggle the seat to lock into one of the many locking positions on the sliders. Once it clunks into position the sound goes away until the next service call.
:lightbulb: #2)
I have also experienced a different clunk accelerating out of low speed corners. In that case, one of the semi-circular brackets holding my rear sway bar had come loose.
:lightbulb: #1)
:lightbulb: #2)
Thanks for the reply and i will check the sway bar, im the only driver so I made sure that the seat was locked in place.... :king:
Another cause may be a loose/broken engine mount.
I wondered about that but not sure where to look for it,. The engine mount is right behind the driver seat? I learned to ignore it since it only happens once in awhile. :help:
