If you become a contributing member you can access the TSB page which includes the litronic retrofit instructions, as well as a bunch of other useful information.
Also try http://www.pelicanparts.com/techarticles/b...tronic_pg1a.htm - I used both the TSB and internet instructions. Both are really helpful.
Search renntech also for Tool Pants' post on extraction tool
In hindsight, I would have also spent the $$ on the DVDs for both the Litronic and short shift install. http://www.renntech.org/forums/index.php?a...code=_9x6_Werks It would have probably saved me lots of frustration.
I concur. The DVD was well worth its cost .... as it stepped through the installation, covering every single issue and leaving nothing to scratch my head about.
Kim
2000 Cab
