Need Help with a 2003 996 C4S Front Spring Change
Hello, I used the DIY for changing the springs (H&R) on a 2003 996 C4S, But I am having trouble with the front strut removal. Do I need to remove the drive shaft in order for the strut to come out.
Can someone Please answer my Question, I have looked around but cannot find any info on a all wheel drive
Thank you everyone.
Miami, FLorida
You don't need to remove the drive shaft - but you do need to remove the axle nut on the wheel hub. The wheel hub will need to slide out and away from the car to clear the strut/spring assembly (after removing the track rod and control arm from the wheel carrier). Don't forget on any car with PSM that the steering angle sensor needs to be re-calibrated after any suspension change/alignment.
Edited by Loren
Loren, any way to tell if the SAS wasn't recalibrated? I had the X 73 upgrade done a few months ago by a good porsche shop (I chickened out of the diy), just wondering.
Only with a PST2 or PIWIS tester (that I know of).
According to the service manual:
"The steering angle sensor must be calibrated after:
- A new steering angle sensor has been installed.
- The PSM control device has been exchanged.
- The steering gear and / or components which change the zero position of the steering angle sensor have been exchanged.
- Accident repairs
- Suspension alignment procedures during which the previous wheel alignment values were changed."
"The steering angle sensor actual value must be checked:
- After a suspension alignment which resulted in no changes being made to the wheel alignment values.
- As a check after steering angle sensor calibration."
