Hello all,
My 2000 C4 is getting noisier it seems..
http://www.stsanford.com/scottstart/uploads/MOV01743.MPG
This video is really more for the sound than the video part, but it gives you an idea of when turning the steering wheel illicits the sound.
Thanks in advance!
Take off the steering wheel and lubricate the electrical contact ring for the horn switch.
Really, you think that's what it is?
Will do, I have some silicone lubricant that my Porsche Mechanic gave me, he says it's the best, but I didn't ask if it was good for this type of use. I've used it for lubricating the seals, etc. You think that would be good?
Try spraying some down in the crack between the steering wheel and the steering column cover, and turn the wheel back and forth to spread it, and see if that stops it. If the spray has one of those little plastic tubes on it, stick the tube down in the crack to spray some on the face of the contact ring.
What can happen is that the spring contact blade on the wheel itself can get some fine debris (or dirt or sand) stuck in it and that is what you hear dragging across the contact ring. lubricating the contact area can break the debris free (sometimes). If that fails, then you need to take the wheel off, and clean the contact area, then re-lubricate it.
I've had other cars that have had the exact same problem. If it is dirt, don't let it go to long, as it will wear a groove in the contact ring.
I have had exactly the same thing. The OPC had just replaced my Top Mounts and then about 500 miles later this noise started. They said it was faulty parts and that this was a known problem. They replaced the parts FOC and it went away.
Sounds dreadful and like something is cranking away on a plastic ratchet.
I'm trying to get a photo of down lower in the steering column, I tried above and it didn't make much diference, seems the sound is coming from where the steering rod goes into the rubber gasket in the firewall.
I have a white plastic fitting which joins in-between the adjustable section of the steering shaft with the part that goes through the firewall, it's cracked in a couple of places and some of the white plastic is missing. should I be alarmed about this? Would it steering rod pop out of place?
  • 3 months later...
I just bought a second hand 2001 boxster S.
It has the exact same problem!
Same sound.
Did you ever work out what the sound is?
JUst a bit of lubricant in the steering column you reckon?
Thanks.
  • 8 months later...
Sorry for bringing this old thread back to life, but I have the exact same noise and I cannot figure out what it is. Any suggestions? From what I read here the silicon solution did not work. Any other ideas? Could it be the top-mounts?
It sounds to me like a suspension joint making the noise but it could be the upper strut mounts. Noises like this are sometimes hard to locate as the sound can travel through components making it rather hard to pinpoint. Purchase a mechanics stethoscope and get a friend to turn the wheel while you have a listen at all the suspension joints.... sometimes you can even feel the joint in question vibrate more then the others.
The thing is, I am 90% certain the noise can only be heard from inside the cabin. Wouldn't this indicate that it has something to with the steering column?
It sounds very loud to me, louder then any column bushing I've ever come across...... are you sure the noise can't be heard from outside of the car?? Sound can travel through components and be very misleading. Try standing outside the car well reaching through the window and turning the wheel and let us know what you find.
I have experienced this noise in one of my old race cars. it had to do with the steering wheel pulling on the steering shaft, I'm not sure as to how you could of had this happen during driving though. Is there some possibility of damage in the front suspension bushings and links? Like maybe you hit a hard bump in the road or a pothole? I would most definately remove the airbag and inspect it while making the noise to get a better idea. But before you remonve the steering wheel I would inspect the front suspension for weak/broken bushings or possibly bent tie rods. Do any of your cars track off ie. pull to one side or the other? It is harder to tell in 996's due to their pwer steering but you would still tend to notice if you let off the wheel on a straightaway. There is a possibility that if this car has the old school feeler arms instead of contact pins that one of the feelers is out of place but that is highly doubted/ impossible. If you inspect the front end and all appears even and well. Then move inside the car and listen with your head by the pedals to the hear if the joint is rubbing at all. I can only tell you this the noise is because the shaft that the steering wheel is bolted to is stressed for some reason or another. Best of luck with it! Jim=)
