My 2000, 2.7 threw a code.
The new and now trust OBD II tells me it is an 1130. The board, thanks, tells me lean O-2 (4-6)
It is not coupled with the 1128.
It would appear to be a local problem 4-6.
Cleared the code. So far so good.
Is there a check, clean, replace checklist?
Is there anything I should be doing? (besides, obviously, checking general performance)
If P1128 (or P1130) (oxygen sensing at rich threshold) is stored in the memory, this means that the fuel/air mixture is too lean.
Air leaks ahead of the oxygen sensors can lead to a fault in adaptation
- Check exhaust system for leaks.
- Check intake air system leaks.
