Is there some sort of trick to removing the fuse panel on my '97 Boxster?
The manual says to "pull the cover off at the finger hole" but my doesn't seem to budge and I don't want to crack the plastic.
Tim
Tim
The cover is on quite tight on my 2001 Boxster. I just gave it an extra pull. I don't think you could crack it, it's quite thick plastic.
