Here's the question: apparently there are at least two different part numbers associated with the CDC-4 cd changer: 996.645.140.00 and 996.645.140.02
Can anyone advise which one will be compatible for a 2003 996 TT with a CDR23 head unit (w/o navi)? As far as software is concerned, I hear that it's pretty much plug and play with the CDC-4 and CDR23. Why do I hear that may need to be programmed? Thanks for all/any insights!
While I am at it, what's the correct part # for the fiberoptic harness/cable? I saw one of Loren's postings but I am still confused. I am an audio techno idiot.
Edited by TurboLove
996.645.140.02 replaces 996.645.140.01. The parts list says it is okay to use 996.645.140.01 until the stock is gone. But you may want the Tequipment kit 000.044.900.72 which includes cables and mounting hardware (except the fiber optic cable).
The fiber optic cable you need will depend on the options already on the car (and whether the car is LHD or RHD).
Do you have the BOSE (option 680) or Harman (option 490) sound system? Do you have the telephone option?
The full CDC4 installation instructions are here for viewing by Contributing Members.
(ps. I deleted your second post as your question is answered here. Please do not double post. Thanks!)
Thanks for this information! I appreciate the clarification. The car is LHD and has the BOSE system. I dont have the phone option.
I think and please confirm that the parts in addition to the cd changer I still need are the harness 996-622-708-00 and bracket 996-645-229-00.
PS- Thanks for deleting my other post since I couldnt do it myself.
Besides the 996.622.708.00 fiber optic cable you will need:
Part Number Qty. Description
996 645 140 02 1x CD changer CDC4
996 645 229 00 1x Holder for CD changer (four-wheel drive)
999 500 078 00 2x M6 press-in nut
999 507 532 02 2x U-clip
900 378 179 09 5x Hexagon-head bolt M6 x 16 - EN 1665
900 378 188 09 4x Hexagon-head bolt M6 x 20 - EN 1665
N 014 128 13 6x Countersunk screw M5 x 8 - DIN 7985
N 903 352 04 1x Pin for cross section 1.0 - 3S
N 103 357 01 1x Pin for cross section 0.35 - 1S
999 650 138 22 1x Pin for cross section 2.5 - 5.02
000 044 900 81 1x Electric wiring set
