The scanner said it's a fault for the secondary air system banks. Any idea what this means? My car is supercharged, but it's been on there for while and I've never had a CEL before. The car seems to be running fine and making boost.
Dog: Is your air pump turning on when you start the car cold? It should run for about a minute after a cold start. If it is running, check the hoses from the pump for leaks. Check the changeover valve's electical and vacuum connections. If pump does not start, check the relay and the electrical connection to the pump.
