I wanted to know which wire is for phone mute, ground, constant power and switched power. Any help would be appreciated.
Please try using the search feature here. I found this question has been answered more than a dozen times already.
Telephone prep connector. On it you will find:
+12 volts unswitched (red/green)
+12 volts switched (green/black)
Ground (brown wire)
Telephone Mute Signal (yellow/black wire)
And don't worry if you blow it.
The crap Becker head unit will work on occasion, and a good number of times a call will come in, radio mute and say 'phone' and when call is over, you will get a blank faceplate with music in the background. When you turn it off and back on, all your presets will be back to '0' and you have to reset it.
Trust me, I've had this same thing in my '99 C2 Cab, and it still sucks in my '04 C4S Cab. Becker makes a crap head unit. :soapbox:
Best of luck with your interface.
