What is an acceptable amperage drain on a 99 C2? With the car closed up, the front trunk lock pushed down to simulate a closed trunk I am getting a reading of 1.0 amps. This seems high to me. Does anybody else have any readings they would like to share?
Is your key in the ignition?
It's too cold outside for me to go do the experiment, but 1 amp is way
too high. That'll drain the battery in no time, a couple days and it'll
likely be to dead to crank the engine.
Bill
1 Amp, should have a leak somewhere. Car closed and alarm on, I thought it would be in the 10-20 milliamp range?
Around 30mA is what you want. It will take around 45 minutes for all the control units to "go to sleep" and get an accurate reading.
