installing parkassist on a P996
Hello,
I am having my bumpers of my 966 re-sprayed. It's a 996 C4 tip. November '98. I was wondering whether it is very difficult to install parkassist. Drilling holes into the bumper won't be much of a problem, but what about the correct wiring. Has anyone tried to install parkassist? Any idea how much approximately this is going to cost. I'm thinking of using original Porsche parts (sensors etc.).
Looking forward to your advice,
jo996
the netherlands
There does not appear to be a kit to retrofit the ParkAssistent option. Looking at the schematic it does not appear to be too complex. But routing the wires in the car may be the big problem.
The ParkAssistent consists of:
- a control module which is located under the driver's seat together with a cover plate.
- four ultra-sound sensors which are installed in the rear bumper.
- an audible signal transmitter which is integrated into the instrument cluster.
Electrical connections need to be made between the each of the four sensors, the control unit, reverse signal wire, the instrument cluster, power and ground.
