P1117 Oxygen sensor heating after TWC, bank 1
Potential causes:
Heating current too high
– Heating resistance too low
– Short to B+
Heating current too low
– Short to ground
– Corrosion in connector
– Break in wiring
Open circuit – Break in wiring
– Heating resistance too great
Internal resistance of oxygen sensor too high
– Open circuit in sensor line
– Oxygen sensor
How many miles on your car? It is not unusual to lose an O2 sensor after 60,000 miles.
Bank 1 on a Carrera would be the drivers side - sensor after the cat.
You will need a cat wrench or a 22 mm wrench. Do not get any oil (or any other substance) on the sensor. The sensor should come with high temp anti seize put that on the threads but not on the sensor.
