I have 97 boxster and I have 70K mile on it
The problem is when my car is cold it woks fine and there is no problem with the transmission but when it gets heat it about +180 the transmission does not shift to 3rd-5th I see the rpm goes up but there is not shifting its like having the gear on N .then I see the gear flash between 4th and d and the car don’t shift anymore .when I restart the car it does work for 2 minutes then its break or I have 2 keep it at the 2nd .
The problem is getting worse now and the last thing I want to do is replacing the transmission .the dealer said they don’t fix transmissions they just replace them. Any way when this start happening the is give me a hard push when it shift from N to 1st then 2nd .this problem happen only when the car is hot but when its cold every thing is fine. Also I see some oil leaking when the problem starts happening, not always but sometimes.
I do smell something burning sometimes but it goes away after few minutes.
The dealer said the transmition flud is burnd but he is not sure if this is the problem or not.
any Ideas
:help:
Edited by nightghost
I have had major transmission problems at 116,000 Kms. I am almost sure your transmission will need a rebuild.
Mine started with not going into first when hot at a set of lights. Then i lost drive, its started to slip very badly.
I then had the auto fully re-built. It was drivable, but once warm i.e 30 minutes of running, it would STILL not go into first gear and it was slipping between gear shifts.
The Auto computer was replaced and that fixed the problem of it not going into 1st gear manually.
Its currently having the valve body and torque convertor solenoid worked on. apparently there are plates in the valve body that are destroyed. So when i get i back i am hoping that after having all the internals replaced, the tip computer replaced, and now the valve body insides rebuilt it will be normal.
so... i think your auto is toast !!! The life of the engine and auto is around 110 - 120,000 kms. If your are lucky that is. Mine is also a 97.
