I noticed at tonight's fill-up that the trim piece on the inside of the front window at the top is detaching itself from the hardtop. This probably helps explain why I've been getting window icing on the inside of the car!!
I haven't driven the car in quite a while and I didn't notice this when I installed the top at the end of October. I suspect that to get at it, I'll also need to remove the hard plastic trim piece above the window.
Can anyone help me figure out how to install this correctly?
