Is there a DIY for cleaning the MAF and tightening the bolts for the Air Intake Throttle Body. I have tried everything to get rid of error code 1128. Replaced air filter with K&N filter, checked all hoses and no air leaks. Still, every 150-200 kms, the CEL comes on. I would like to try cleaning the MAF and tightening the bolts a try before I take to a dealer who will empty out my pocket.
Remove the MAF and spray liberaly with electronics cleaner you can get at an ACE hardware store. Put it back in. Remove the intake tube to the throttbody and open the butterfly valve slowly, all the way. Spray liberaly with carb cleaner. Reinstall intake tube. Reboot computer by removing negative battery cable for 2 minutes and then reconnect. You're done. It will take a few drive cycles to get your idle back to being smooth.
2469 P1128 0-116 page 1
p1128
Printed in Germany – 4, 2002
0-116 P1128
360 Oxygen Sensing Adaptation, Idle Range, Bank 1 -
Below Limit
Diagnosis conditions
• Oxygen sensing system active
• Time elapsed after engine start-up: 250 to 350 seconds (USA)
• Time elapsed after engine start-up: 302 to 402 seconds (RoW)
• Engine temperature greater than 60 °C
Possible fault cause
♦ Incorrect signal from MAF sensor
♦ Fuel pressure too high
♦ Fuel injector leaking
♦ EVAP canister purge valve open
Affected terminals
Diagnosis/Troubleshooting
♦ If DTC P0445 (fuel tank vent valve - short to ground) is stored, correct this fault first. An open EVAP canister
purge valve can lead to the lean threshold being reached.
♦ For vehicles in the USA, the upper load range will probably not be reached. The only case in which a fault could
be stored is during driving while towing a trailer or caravan on a hill.
♦ Contrary adaptation values in connection with misfiring point to incorrectly adjusted control timescheck control
times and adjust if necessary.
♦ If the fuel tank reserve light is switched on, no fault is entered.
Work instruction Display OK If not OK
1 Check signal from MAF
sensor.
♦ Connect special tool 9637.
♦ Measure voltage at pin III/23
and ground
♦ Switch on the ignition.
0.9 to 1.1 V. Replace MAF sensor
♦ Start the engine. Approx. 1,4 V
2 Check fuel pressure
Note!
DME 7.8 DME 7.8
2469 P1128 0-116 page 2
p1128
Above Limit
♦ Intake air system leaking
♦ Fuel pressure too low
♦ Volume supply of fuel pump too low
♦ Fuel injectors fouled
3 Check fuel pressure regulator,
vacuum connection
and fuel return line
♦ Remove vacuum hose from fuel
pressure regulator
♦ Connect special tool 9103/2 to
vacuum hose
♦ Start the engine.
0.4 - 0.6 bar Check the intake air
system for leaks
and check vacuum
line to fuel pressure
regulator for restrictions.
♦ Check housing of fuel pressure
regulator for damage and deformation
Replace the fuel
pressure regulator if
it is damaged with
the result that the
spring pre-tensioning
is increased
4 Check EVAP canister
purge valve
♦ Disconnect hose from EVAP canister
purge valve to intake system
at EVAP canister purge
valve
♦ Remove connector of EVAP canister
purge valve
♦ Connect special tool 9160/1 to
♦ Generate vacuum of approx. 0.7
bar
The vacuum must
not fall below 0 bar
after 10 minutes
5 Check fuel injectors for
leaks
DME 7.8
2469 P1128 0-116 page 3
DME 7.8
p1128
♦ PCV valve leaks
♦ Cap of oil filler neck not closed correctly or seal is damaged
Affected terminals
♦ Air leaks ahead of the oxygen sensors can lead to a fault in adaptation Check exhaust system for leaks.
1 Close cap of oil filler neck
properly or replace the
seal
2 Check signal from MAF
sensor.
and ground
3 Check exhaust system for
leaks
4 Check for air leaks in
intake air system
5 Check PCV valve for leaks
6 Check fuel pressure
7 Check volume supply of
fuel pump
8 Fuel injectors fouled ♦ If preceding Check Points were
negative, the fuel injectors may
be fouled
♦ Clean fuel injectors (ultrasonic
cleaning device) or replace them
Note!
  • 5 weeks later...
.... error code 1128. Replaced air filter with K&N filter, checked all hoses and no air leaks. Still, every 150-200 kms, the CEL comes on. I would like to try cleaning the MAF and tightening the bolts a try before I take to a dealer who will empty out my pocket.
My MAF issues disappeared after removing the K&N style oiled filter and replacing w/ dry paper OEM element. I'd try that plus the electronic cleaner mentioned above.
  • 3 years later...
p1128
0-116 P1128
Below Limit
Affected terminals
sensor.
and ground
Note!
DME 7.8 DME 7.8
p1128
Above Limit
vacuum connection
pressure regulator
vacuum hose
♦ Start the engine.
system for leaks
and check vacuum
Replace the fuel
it is damaged with
the result that the
is increased
purge valve
valve
purge valve
bar
The vacuum must
after 10 minutes
leaks
DME 7.8
DME 7.8
p1128
♦ PCV valve leaks
Affected terminals
seal
sensor.
and ground
leaks
intake air system
fuel pump
be fouled
Note!
Has anyone used the special tool 9637 to check the MAF? Where would I find it?
